Is it possible to create alerts based on a custom poller value? Example: I monitor satellite signal levels on a modem and need to create an alert if that value drops below a certain value. How can i do this?
you just go to advanced alerts, create a custom poller alert where OID=<yourOIDofyourpoller> and CustomPoller.Status >threshold.
e.g.:
rory81,
It is. For more information, see "Creating and Configuring Advanced Alerts", specifically the section, "Setting a Trigger Condition for an Advanced Alert", where you can select a Custom Node Poller as the Type of Property to Monitor, in the SolarWinds Orion Network Performance Monitor Administrator Guide.
