Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Networkmonitoring from Home-Computer
mreich
Hi
We have to look for a Tool which enables us to check/monitor the company's network. This network will have Home-Users. Some of this home-users will be administartors, which has to be able to work with those tools from their Home-Computers.
I think solarwinds will be able to do so, but I was not able to find a description on the homepage about this. Allso the subjects of the topics are not giving informations about this.
Does anybody know how this will go with Solarwinds? Can I install an Admin-Tool on a Laptop and connect using RAS, ISDN or another conection and use all tools of solarwinds for checking the Company's Network?
Thanx for all feedback,
Mathias
Find more posts tagged with
Accepted answers
All comments
rknight
This will work, but you will have to have a license per machine.
I install a remote control program (pcAnywhere, Windows Terminal Services, etc) on my Network Management station and then I log in to it remotely from home to use the Solar winds tools.
Cheers
Ric Knight
Bryan
If you really want a untility capable of remote administration and user rights, you need to look at ORION. If only one user at a time is going to be administering, then you could use the toolsets EE and use some sort of Remote Desktop utility. I use Timbuktu but I have DSL for my home connection. If your using dial up and RAS, a remote desktop utility may not be your answer.
Lockheed Martin
Atlas V Launch Operations
Network Engineer
MMI
Mathias,
The way I use it to check the network from home is to VPN into my network, then remote control (we use VNC) into the SolarWinds server to do whaever you need to do.
Paul
jmooney
I also check my network from home by using VPN and the Remote Desktop Connection from Microsoft.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
