Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Cisco Serial No via SNMP
Jules2003
Hi
Using the ip network browser (or anything else in the toolset) is it possible to aquire the Serial Number via SNMP private string. I can get most other things like the ios version, the uptime stats/ports.
Any help would be great.
Cheers
Julian
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Depends on what type of device it is.
You can for most Cisco routers....
-=Cheers=-
NG
mlpalmer
Cisco Works reports a serial number so it can be done. The problem is that this serial number is for the motherboard or something. It does not match up with the chassis serial number. So, using this reported serial number for smartnet for instance, is not possible. What we have done is to use one of the available SNMP variables like "contact" to report the chassis serial number which along with "location" gives us what we need to know.
Network_Guru
Actually, it depends on the type of Cisco device you are polling.
A Cisco7206 has the serial number printed on the chassis, which is different than the processor board serial number - as Mike has posted.
Integrated devices such as a Cisco800 series or 1700 series router use the Processor ID as the device serial number as well
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
