Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
RUN-TIME ERROR '430':
niltinho
After I installed Toolset Eng. Edition NPM still working fine but MAp Maker, NEtwork Dicovery when i try to run it I got a error saying: Run-time error '430': Class do not support automation or do not support interface. Already updated MDAC was suggested by some else but no luck!
Any comments will be very appreciated.
Thank you.
Niltinho
CCNA,CNA,4MCP
Find more posts tagged with
Accepted answers
All comments
DonYonce
Sounds like a DLL is downrev.
Could it have been an older release of the Engineer's Edition Toolset ?
I suggest rerunning the Orion install. Do not uninstall Orion, just rerun the Install.
It should correct itself.
niltinho
Don, did what you advised but no luck, the Tollset is v.8 and Orion 7.5. Main problem now is that im desperate in need to run Network discovery.
Niltinho
CCNA,CNA,4MCP
DonYonce
Now I understand the issue. Toolset v8 and Orion 7.5 Discovery Engine are not compatible.
When I said "reinstall Orion", I assumed you would install Orion V7.8
A possible work around for Orion V7.5 is :
From the "Network Performance Monitor v7" directory, run the following command
C:\Windows\system32\regsvr32.exe SonarDiscovery5.dll
This will reregister the Sonar Discovery engine and may fix the issue.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
