Hi Forum,
Is there a way to report peak interface utilization which exceeds X% for more than XX consecutive minutes during business hours?
Thanks in advance.
@KMSigma.SWI @bobmarley - Can you help please?
I grabbed this query from a recent post. It's probably a good starting point. You could insert something on the Where clause tuned to your interface (or circuit) where H.InAveragebps is greater than x number. Same with H.OutAveragebps
SELECT tolocal (downsample (h.DateTime ,'00:15:00')) as [Timestamp], N.Caption as [Device Name], I.Caption as [Interface Name], I.inBandwidth as [Bandwidth],avg(H.InAveragebps) as [AverageIn],avg(H.OutAveragebps) as [AverageOut]FROM Orion.Nodes NINNER JOIN Orion.NPM.Interfaces AS I ON N.NodeID = I.NodeIDINNER JOIN Orion.NPM.InterfaceTraffic AS H ON I.InterfaceID = H.InterfaceID --below will only show the last hour, adjust as necessaryWHERE N.Caption LIKE '%NODECAPTION%' AND I.Caption LIKE '%CIRCUITNAME%' AND h.DateTime > ADDDATE('Hour', -1, GETDATE())GROUP BY N.Caption, I.Caption, I.inBandwidth, downsample(H.DateTime,'00:15:00')Order By Timestamp DESC
Thank you @bobmarley, and sorry for my delayed response. I have seen this thread. Quick check please - does the query capture results, when the interface was utilized say more than 90% for a continuous time period of XX minutes? Not really good with scripting, sorry about that.
I put some comments in the query below.
The circuit I was using was 10GB or 10,000,000,000. 90 percent of that is 9,000,000,000
That is shown in the Where clause as H.InAveragebps >= '9000000000' also H.OutAveragebps >= '9000000000'
This line tells the query to get only the last hour, adjust to your needs ADDDATE('Hour', -1, GETDATE()
The query will only report results for time periods that exceed 90 percent for each 5 minute average.
--Changed this down to 5 minute intervals to get all polls, match your interface polling timeSELECT tolocal (downsample (h.DateTime ,'00:5:00')) as [Timestamp], N.Caption as [Device Name], I.Caption as [Interface Name], I.inBandwidth as [Bandwidth],avg(H.InAveragebps) as [AverageIn],avg(H.OutAveragebps) as [AverageOut]FROM Orion.Nodes NINNER JOIN Orion.NPM.Interfaces AS I ON N.NodeID = I.NodeIDINNER JOIN Orion.NPM.InterfaceTraffic AS H ON I.InterfaceID = H.InterfaceID --Put your node and interface name here ADDDATE('Hour', -1 tells the query how far to go back. The circuit I used had a bandwidth of 10000000000, 90 percent of that is --9000000000 so this will display only the times when the circuit was over 90 percent.WHERE N.Caption LIKE '%YOURNODENAME%' AND I.Caption LIKE '%YOURCIRCUITNAME%' AND h.DateTime > ADDDATE('Hour', -1, GETDATE()) AND H.InAveragebps >= '9000000000' OR N.Caption LIKE '%bdc-rtr-isp-1111-1-NEW%' AND I.Caption LIKE '% Circuit ID: L4YS750288%' AND h.DateTime > ADDDATE('Hour', -1, GETDATE()) AND H.OutAveragebps >= '9000000000'--Changed this down to 5 minute intervals to get all polls, match your interface polling timeGROUP BYN.Caption, I.Caption, I.inBandwidth, downsample(H.DateTime,'00:5:00')Order By Timestamp DESC
Here is another way that may be easier to read and follow. Included the interface percentages in and out and did the Where differently to include devices with the word ROUTER in the in the name.
The Where calculated on percentage of in or out traffic.
--Changed this down to 5 minute intervals to get all polls, match your interface polling timeSELECT tolocal (downsample (h.DateTime ,'00:5:00')) as [Timestamp], --Added Utilization in and out in percentageN.Caption as [Device Name], I.Caption as [Interface Name], I.inBandwidth as [Bandwidth], I.InPercentUtil as [Utilization In], I.OutPercentUtil as [Utilization Out],avg(H.InAveragebps) as [AverageIn],avg(H.OutAveragebps) as [AverageOut]FROM Orion.Nodes NINNER JOIN Orion.NPM.Interfaces AS I ON N.NodeID = I.NodeIDINNER JOIN Orion.NPM.InterfaceTraffic AS H ON I.InterfaceID = H.InterfaceID --Change the name ROUTER to match nodes in your network.WHERE N.Caption LIKE '%ROUTER%' AND h.DateTime > ADDDATE('Hour', -1, GETDATE()) AND I.InPercentUtil >= 90 OR N.Caption LIKE '%rtr-%' AND h.DateTime > ADDDATE('Hour', -1, GETDATE()) AND I.OutPercentUtil >= 90GROUP BYN.Caption, I.Caption, I.inBandwidth, I.InPercentUtil, I.OutPercentUtil, downsample(H.DateTime,'00:5:00')Order By I.Caption DESC
