Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Account Limitations
rstier
I would like to create an account limitation for a particular group that allows them to see all systems that start with the hostname of "NT". Easy enough by doing a node name pattern limitation of "NT*". In addition, there is about a dozen other nodes that I would like them to also see, all with various names.
I thought I could just create the first "node name pattern" limitation and then an additional "group of nodes" limitation with those dozen nodes selected. Is there a way to do this with SolarWinds? It appears by this statement you cannot:
"You can create Account Limitations that will limit the Network Devices this Account has access to.
If mulitple Limitations are added to this Account, the Account will be limited to only the Devices that match ALL Limitations. "
Thanks in advance,
Ron
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Hi Ron,
It looks like you will have to add a custom property and add a description to all the nodes you want that group to be able to access. Then select that description in the Web admin "accounts" page.
-=Cheers=-
NG
rstier
I was afraid of that. Unfortunately that isn't very dynamic. At least by specifying the node name pattern of NT*, I can get newly provisoned servers automatically added to the view without the extra steps. Unfortunately that leaves out the few non "nt*" nodes I need them to see as well.
In any case, thanks for the response!
Ron
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
