Do you have the SWQL data from the edit on that widget so we can see what it should be
yes here it is
SELECT TOP 10 n.CPULoad,n.Caption,n.Status,n.CustomProperties.Locations AS CustomProperties_Locations,n.DetailsUrl FROM Orion.Nodes n order by n.CPULoad descending
IT IS SHOWING ONLY ADMIN ACCOUNT
I have recreated the dashboard and a basic account with no permissions and it still shows the line chart. Is the internet browser the standard user is using, supported? Using edge or chrome not internet explorer.
Have they tried to access on another pc looks like a local user issue.
i tried all browser . same issue . can you put some account limitation and check
Just to confirm I see the same behavior. I only see it on my account. When I switch to another user and log in to test visbility as its multi tennant I cant see the bar.
as per SolarWinds you need to upgrade to latest version
