Any ideas?
Could you check the permissions for C:\ProgramData\SolarWinds\Orion?
I can. What am I looking for?
If you can check the folder permissions you may need to amend the permissions of “SolarWinds Orion Application Pool” account for C:\ProgramData\SolarWinds\Orion - add the right to Read, Write and Modify
just wondering what happened to change this. existing reports worked last month.
Did the folder permissions require a change? Have you upgraded recently?
Use this to check and repair
https://support.solarwinds.com/SuccessCenter/s/article/Check-permissions-using-the-Orion-Permission-Checker
__PRESENT
That worked, thank you. I did upgrade but that was a couple of months ago. Any idea why this happens? we did a ha failover recently, is there any way that may have changed permissions?
Honestly I don't have an accurate answer to your query (it depends on what is being enforced on your SW VMs), we were always asked/told to exclude all folders related to SolarWinds from Antivirus / Defender / Security checks / guidelines that the company enforces on the VM's/Servers on which SolarWinds runs.
Yes, HA Failover could be the reason as to why you encountered this issue, probably it was running fine on the Primary poller and when you failed over to the standby poller this might have happened due to permission issues on the folders of your standby poller.
Hope this helps.
ok, thanks. well, we did a failover to the standby for a bit then back to the primary where these permission issues happened. the failover was last week so we didnt notice anything until we ran a report.
