Hi Guy, Is there a way to hide or remove this icon, so that users can't see and click on it?
it will hide the web page element .sw-platform-connect-info so this should touch just the icon.I don't expect any side effect.
As a workaround for a big part of OrionWeb console, you can modify CSS this way:edit file\Program Files\SolarWinds\Orion\Web\SolarWinds.cssat this row to the end:.sw-platform-connect-info {display:none;}edit file\Program Files\SolarWinds\Orion\Web\ui\Views\Shared\_Layout.cshtmlat this row to the end:<style>.sw-platform-connect-info {display:none;}</style>After the change, force refresh Orion in browser.This should fix it for most parts of OrionWeb console.To fix other parts, you need to modify multiple files this way:
$orionWebsitePath = "C:\Program Files\SolarWinds\Orion\Web\apps\apps\"$fixPageStyle="`r`n.sw-platform-connect-info {display:none;}"Get-ChildItem -literalPath $orionWebsitePath -Recurse -Filter index.html | Foreach-Object { $content = Get-Content -LiteralPath $_.FullName $content += $fixPageStyle Set-Content -Path $_.FullName -Value $content}
