can some one help and assist on this, we need to setup Monitor devices using SolarWinds API hosted on different network has no communication with Solarwinds host Network
Hi Team
any update on above ask
I think we are unclear how to help, you stated there is not connection from the thing you want to monitor back to SolarWinds. If there isn't a connection, there isn't a solution.
HI JM,
we want to monitor some server that come under compliance zone and due to some security we don't to open SNMP port for those server. can we link those server via API? if yes, then how and steps?
Seems like the API security hole is bigger than the SNMP security holeInstall an agent to send traffic over 1777x
Or setup something weird like:
Device goes "Hey SWIS i'm ok"Solarwinds says "Device says it's OK", ELSE "Device says it's broke" OR "Device has gone quiet"
