Upto Version 2020.6 we were able to see column width marker in reports Post upgrading to 2023.1.1 it's not visible.
Before upgrade
Case #01335583
Yes, the column markers have disappeared after the upgrade. Have opened a support ticket.
@nafeeskhan29 @abdhijasharma pls share the ticket number
Did you open a support ticket by any chance? I will send this to folks internally so we can get a defect opened up if needed.
@RaviK@serena please check
