Hello,
Did anyone ever try to use "Component Monitor Wizard" function to monitor Azure Application Gateway?
I've been told from support as this is out of boundary support as there's no such template could be used for monitoring Azure Application Gateway, so that's why I tried my luck in there to see if any folks did something similar before.
After I click "Next, I see below. It requires me to input the server IP address in here but Azure application gateway doesn't own it at all. On this occasion, how can I achieve the goal to monitor it or it's not something we can do in terms of monitoring it from Solarwinds SAM? Please advise, thank you
