How to add data and time duration?
How are you producing this?Can you show us your S(W)QL code or a screenshot of your reports logic?
hi
SELECT [data].[DisplayName] AS [DisplayName],[data].[Application].[Node].[DisplayName] AS [DisplayName1],[data].[InstanceSiteId] AS [InstanceSiteId]FROM orion.apm.component AS dataWHERE((([data].[Application].[Node].[CustomProperties].[TETCO_HQ_URL]) = ('TETCO-HQ-URL')))WITH NOLOCK
OK - so I don't have or use APM so can't explicitly answer.For me, what I would do is open SWQL Studio, then navigate to the orion.apm.component table and search through the various fields there to identify if your required data is available (it might be available via the implicit joins). Once you've identified the fields, you will need to add those fields into the SELECT statement.So, for e,g, let's say the field is called LastResponse for the down date then your SELECT statement could look like:>> SELECT [data].[DisplayName] AS [DisplayName],[data].[Application].[Node].[DisplayName] AS [DisplayName1],[data].[InstanceSiteId] AS [InstanceSiteId], LastResponse AS [Down Date]
I don't know the field in the database you need to find but I can give you the math needed to turn the date into a current duration, just replace AlertActive.TriggeredDateTime with your field. CONCAT(CASE WHEN (MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))%1440)<720 THEN (MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))/1440) ELSE ((MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))/1440)-1)END,'D ',CASE WHEN (MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))%1440%60)<30 THEN ((MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))%1440)/60) ELSE (((MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))%1440)/60)-1)END,'H ',(MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))%1440%60),'M') AS Duration
I use this on our alert screen, here is what the output looks like:
Hi Sadiq,
For me it is not really clear what you are looking for?
hi edwin
i want see all dates and times as well down duration on the same report
hi bro.
query is not valid
Interesting, so I didn't include any of the FROM or JOIN statements that you may need because I figured you'd be using a different field. I've included the complete query below. I use this for a table of a modern dashboard.
SELECT (MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))) AS Seconds, AlertActive.TriggeredDateTime, ToLocal(AlertActive.TriggeredDateTime) AS LocalTriggerTime,AlertActive.TriggeredMessage,Nodes.Caption,Nodes.IP, Nodes.DetailsURL,AlertConfigurations.Severity AS Severity,CONCAT('solarwinds.clemson.edu/.../ActiveAlertDetails.aspx AS AlertURL,CONCAT(CASE WHEN (MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))%1440)<720 THEN (MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))/1440) ELSE ((MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))/1440)-1)END,'D ',CASE WHEN (MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))%1440%60)<30 THEN ((MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))%1440)/60) ELSE (((MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))%1440)/60)-1)END,'H ',(MinuteDiff(AlertActive.TriggeredDateTime,ToUtc(GetDate()))%1440%60),'M') AS DurationFROM Orion.AlertActive AS AlertActiveINNER JOIN Orion.AlertObjects AS AlertObjects ON AlertActive.InstanceSiteId=AlertObjects.InstanceSiteId AND AlertActive.AlertObjectID=AlertObjects.AlertObjectIDLEFT JOIN Orion.Nodes AS Nodes ON AlertObjects.RelatedNodeId = Nodes.NodeIDINNER JOIN Orion.AlertConfigurations AS AlertConfigurations ON AlertObjects.AlertID=AlertConfigurations.AlertIDWHERE AlertActive.Acknowledged IS NULLORDER BY Seconds ASC
hi all
i got exact query which i was looking for
SELECT
-- Device name
StartTime.Nodes.Caption AS [Device]
, starttime.nodes.detailsurl as [_linkfor_Device]
,'/Orion/images/StatusIcons/Small-' + starttime.nodes.statusicon AS [_IconFor_Device]
-- Application name
,a.Name
,a.detailsurl as [_linkfor_Name]
, '/Orion/images/StatusIcons/Small-' + a.StatusDescription + '.gif' as [_iconfor_Name]
-- Down Event Message
,starttime.message as [Down Event Message]
-- Down Event time stamp in local time zone
,ToLocal(StartTime.EventTime) AS [Down Event]
-- Up Event Message
,(SELECT TOP 1
Message AS [Message]
FROM Orion.Events AS [EndTime]
WHERE EndTime.EventTime >= StartTime.EventTime
AND (EndTime.EventType = 504 -- up
OR EndTime.EventType = 510 -- warning
OR EndTime.EventType = 509 -- critical
OR EndTime.EventType = 512) -- resumed
AND EndTime.NetworkNode = StartTime.NetworkNode
AND EndTime.NetObjectType like 'a%'
AND EndTime.NetObjectID = StartTime.NetObjectID
AND EventTime IS NOT NULL
ORDER BY EndTime.EventTime
) AS [Up Event Message]
-- Up Event time stamp in local time zone
ToLocal(EventTime) AS [EventTime]
) AS [Up Event]
-- Downtime duration in minutes. Based on either the current time (node is still down) or Up Event time (node is back up)
,CASE
WHEN (SELECT TOP 1 ToLocal(EventTime) AS [EventTime]
ORDER BY EndTime.EventTime) IS NULL THEN MINUTEDIFF(StartTime.EventTime, GETUTCDATE())
ELSE MINUTEDIFF(StartTime.EventTime,
(SELECT TOP 1 EventTime
WHERE EndTime.EventTime > StartTime.EventTime
ORDER BY EndTime.EventTime))
END AS [Minutes]
-- This is the table we are querying
FROM Orion.Events StartTime
join orion.apm.application a on a.applicationid=starttime.netobjectid
-- EventType = 1 is to correlate with our 'Down Event' time stamp from line 13 above
WHERE (StartTime.EventType = 505 -- down and unknown
or StartTime.EventType = 513 -- unreachable
or StartTime.EventType = 511) -- suspended
and StartTime.NetObjectType like 'a%'
and daydiff(starttime.eventtime,getdate())<31
--remove the comment from this part to make this searchable in a custom query resource
-- and ( StartTime.Nodes.Caption like '%${SEARCH_STRING}%' or a.Name like '%${SEARCH_STRING}%')
-- Order our results from the newest to oldest 'Down Event'
ORDER BY [Down Event] DESC
Brother, can you give me simple query to view the total down time from last node down and last node down time?.
Hi, Maybe the attached SWQL query will help you:
SELECT IPAddress, Caption, DetailsURL, Location, Status, TOLOCAL(LastSystemUpTimePollUtc) As [Last Poll], CASE WHEN MINUTEDIFF(LastSystemUpTimePollUtc,GETUTCDATE()) > 1440 THEN (tostring(ROUND(minutediff(LastSystemUpTimePollUtc,GETUTCDATE())/1440.1,1)) + ' Days') WHEN MINUTEDIFF(LastSystemUpTimePollUtc,GETUTCDATE()) > 60 THEN (tostring(ROUND(minutediff(LastSystemUpTimePollUtc,GETUTCDATE())/60.1,1)) + ' Hours') ELSE (tostring(minutediff(LastSystemUpTimePollUtc,GETUTCDATE())) + ' Minutes') END AS [Down Time]FROM Orion.NodesWhere status = 2
Thanks.
