Dear Thwack
I have created a query and its result as follows, but unable to get icon on widget it seems only pink square.
Can you share the swql
SELECT Count(NodeID) as totalNodes , Vendor, VendorIcon as VIconFROM NCM.Nodeswhere SNMPLevel >0GROUP BY Vendor, VendorIconorder by TotalNodes
What you did seems right, and I can't get it to work in the proportional widget, but I can get it to work other places like tables. I also looked at it in other examples, they are using the same field. (examples I used from the article below)
All in on Modern Dashboards - Newsroom - Hybrid Cloud Observability - THWACK (solarwinds.com)It looks the same if you pull the data out of Orion.Nodes as well. If nobody has gotten it to work it might be broken.
Yeah.. correct.. but if we write an SWQL for node status, then we are able to get status icon,, however, i have searched for the path.. mutilple path found for status icon..but not found correct icon for status_up (which seems green tick)
SWQL
SELECT COUNT(1) as value, Status, CASE WHEN Status = 1 THEN '9' WHEN Status =14 THEN 'status_down' WHEN Status =3 THEN 'status_warning' ELSE 'status_unknown' END as icon, CASE WHEN Status = 1 THEN 'green' WHEN Status =14 THEN 'red' WHEN Status = 3 THEN 'yellow' ELSE 'gray' END as colorFROM Orion.Nodes GROUP BY status ORDER BY value DESC
So it works for status only... i think so...
I don't have a server handy at the moment, but what happens if you bring it in using the VendorInfo entity?
SELECT COUNT(NodeID) AS [TotalNodes] , [Nodes].VendorInfo.Name AS [Vendor] . [Nodes[.VendorInfo.Icon AS [VIcon]FROM NCM.Nodes AS [NCM]JOIN Orion.Nodes AS [Nodes] ON [NCM].CoreNodeID = [Nodes}.NodeIDWHERE [NCM].SNMPLevel > 0GROUP BY [Nodes].VendorInfo.Name , [Nodes[.VendorInfo.IconORDER BY COUNT(NodeID)
^ Making best guesses from memory as to the names of the entities and properties.
Dear KMSigma
I returns the output in table as the same as my query but the question is here that how to bring the icon on widget... it is not showing... however, i have opened a case but they also not able to do so, and escalated the case to developer team for further investigation.
