hi all
anyone can help me to run a report for List of resources
thwack.solarwinds.com/.../how-to-pull-the-report-of-list-all-list-resource
hi bro
not getting result
I would assume you copy paste the query correct?
yes
then that's the problem. The nodeID listed there is just an example.
ok . i want list all the nodeID . how can i do that
It is discussed on the link.
Unfortunately, I no longer have a Solarwinds environment so I can't do testing of queries. You will need to play around it. I'm not sure if anyone else has figured out to do it via a query as it seems you will need to have a Node ID as an index to other tables.
I would suggest for you to file a feature request and paste it here and I will vote for it to pick up steam.
ok bro thank you
