Hello,
every time I try to create to "add dynamic query" I am being log off from the console.
I can't even finish to write the query before it happens.
I have an opened ticket but no solution.
Someone has an idea?
Thanks.
Definitely not normal behaviour - Probably best to call support for this one.
I did and two months later still not resolved.
Any leads from that process?
None, they make changed some performance setting of the DB but nothing related to my issues.
I'd expect you to have an error logged somewhere around the logoff event. As this shouldnt happen it's a little hard to guess at, i'd try and find that error/log and go from there.
Maybe test with other accounts or other tables (like if you were defining a nodes group, try a Hosts or WAP or Volumes group or something) and see if the response is the same
