I'm trying to pull a list of Solarwinds SEM devices/nodes, but I can't find any options. Can anyone help me?
Thanks for the help, after updating the version the functionality became active.
In SEM, go to Configure --> Nodes and select the checkbox(es) of nodes as required. On top of it, there should be an export option to export the selected nodes
Thanks for trying to help, but see below that it doesn't have any option to export the nodes:
What version of SEM are you currently running
in 2022 Version is should be seen as above
We are using version 2022.2
Make sure your userid has the proper authority. The admin has right's to export.
I agree that is the next step you must have admin not admin not monitor or auditor.
The screen I shared before is from 2022.4
Very strange because I have administrator permissions. Any other suggestions?
I think this feature was added right after 2022.2.1
Just checked yes it's new feature in 2022.4:
Export nodes
