Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
You do not have access to that view ? problem
Seraphym
hi,
i have a strange problem with orion :
i created a custom view, including all network devices separated in different columns. so far so good.
but if i want to see the details for a node, i get the "you do not have access to that view" error condition. hm ? anyone got an idea where i can fix this ?
Find more posts tagged with
Accepted answers
All comments
DonYonce
Sounds like the Account you are using does not have permission to view any Node Details.
Select "Account Manager" from the Web admin.
Select the Account your are using and click the "Edit" button.
Towards the bottom you can select which view should be used for "Node Details". It's probably set to "NONE".
Seraphym
thanks don, that solved the problem. must have overlooked the parameter.
johnny
Thanks,it also solved my problem.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
