Can you grant read-only access to user accounts for Manage Nodes? I want certain accounts to be able to drill down into node metrics but not make changes. I didn't see a way to grant anything less than node administrator access.
Thanks!
I added a direct link to the new UI in via the custom links widget or adding the link to the users' toolbars. I have switched back and forth from the new UI (I dislike it too. Its missing custom property labels...)
its basically
You can switch to it and grab the link that way too. THen switch back - please provide feedback when prompted. If the developers/UI people keep hearing why we dislike the new UI, they may fix it.
Your version is 'basically' current. The 2022.3 and 2022.4 should have a new version, hopefully a stable general release (GA and not RC) of 2022.4 maybe with a hotfix number too. The hints indicate end of Nov or very beginning of Dec.
Unless you have rules setup to block users from seeing some nodes, all users should be able to deep dive into node metrics. Admin or Node management is not a requirement for that. Is there something specific that you want them to do or see?
I might be going about it wrong. When I try to add Manage Nodes to them, it's Admin or nothing. I want them to be able to sort by location, device type, status, etc. and see all nodes and custom properties related to whatever they are filtering for. I just don't want them to edit/delete. Currently, when they click the Manage Nodes link, they don't have rights to access it.
AHHHHH Try the new manage nodes UI. It allows them to search and filter and schedule maintenance. It will not allow them to edit/add/delete. THe legacy node management can only be accessed by admin and users with node management from what I have noticed. If that is not the issue, please post back. The Global search is pretty powerful now and allows filtering etc. What version of solarwinds are you running? If its near EOL, then try to get it updated as older versions will affect both the global search and new node management UI.
Thanks for the direction! I've been using the legacy view for so long (and prefer it) I forgot about the new UI.
For the new node management UI, is there a way to pin that to a Dashboard? Users can get to it by searching for 'manage' but I can't find a way to pin it.
We are up to date so far as I am aware: Orion Platform HF5, IPAM, SAM HF4, NCM HF2, NPM HF3, NTA HF2: 2020.2.6
I really appreciate the help.
Great stuff. Thanks so much for the help. The custom link works like a charm.
