Hi Networks,
Not related to solarwinds but I would really appreciate if someone can help me with getting mib database of HPE Nonstop server.
if you've got the snmpwalk and have the raw oids you could try here.
http://oid-info.com/
No Not working for me, anyone who can provide the actual HPE Nonstop OIDs or MIBs that will be very helpfull.
I tried polling through snmpv1 I am not getting any information
that is the archive file you have to unzip the archive first, download 7zip or something , then you'll see the list of files which you can edit with notepad.
not happening it gives me weird output
You can still edit the MIB's in notepad if you need to.
Ok I was looking into latest version was expecting to be in text format, so that i can verify some oid before updating my solarwinds mib database
I used the latest MIB 11.80 for Windows. It gives you lots of MIB's to choose from. So you need to know which MIB's you need to get the metrics you want.
Hi @[Deleted User]
thank you for your response , please help me with what mibs you used from the list.
I've just spoken to HP for some of my kit and they said these MIB's should do the job for Nonstop server too.https://support.hpe.com/hpesc/public/docDisplay?docId=emr_na-c04272529@acmtix Adam
