I would like to know is there a way to run a report that has been created in the report writer via Network Config Manager?
I would like to create monthly reports and have them emailed to group.
Thanks for any help on this!
Short answer - Orion Report Scheduler doesn't work in our SSL environment. Our web site pops up with an "Accept credentials" prompt where the user has to hit OK or Cancel and this hoses the Report Scheduler.
Since Report Scheduler tries to simulate a user accessing the web site and reports it fails.
In NCM they have a back end email engine which doesn't run into this limitation.
Why do you want to do it in Network Config Manager?
Write your report in report writer, then set up Orion Report Scheduler to automatically run and email you the report once a month.
