Is there a way to create an Alert for when a Network Device is Flapping? For example, If an Access Point is triggering 20 Down events within 7 days.
Thank you for your help,
Tom
Here's an alert you can probably use as a base - you'd just need to tweak it a little bit to specify for it for your own devices (Access Points).
HiI Think this will work, alerting on nodes that have more than 20 node down events last 48 hours:
Create a custom SQL alert with node as base and add below code:
INNER JOIN(select Count(Eventid) as nroftimes,NetworkNodeFROM EventsWhere EventType=1 --Node down AND EventTime>GETUTCDATE()-48 --Events last 48 hoursGroup BY NetworkNodeHAVING Count(Eventid)>20) AS E ON Nodes.NodeID=E.NetworkNode
You could also use that code if you want a report instead.
Is there an alert for Specific Interfaces flapping defined by a custom property called XYZ as true?
This is the alert we have for flapping interfaces....
Adjust adjust the figures to suit yourself but above 'as is' will trigger an alert if an interface goes down 5 times in 1hr.If you want to narrow it down to a specific interface(s) then you will need to create a WHERE filter to select them. If it's based on a custom property, then you will most likely need to do a join to the interface (or node) CP and reference that in your WHERE statement.
HTH?
Hi, can this be used to set up alerts for flapping BGP routes?
This inquiry should probably be built as a separate thread (best placed in the Alert Lab) so that we don't muddy the waters and solutions.
if I wanted to change it to day and see how many times it flaps..how can I convert the code below to add a count? so far I have the following.
SELECT count (*) as qty, Interfaces.Fullname, Interfaces.InterfaceIDfrom Interfacesjoin events on interfaces.InterfaceID = events.netobjectidwhere eventtime > dateadd(day,-1,GETDATE()) and eventtype ='10'group by eventtype, interfaceid, fullname, message having count (eventid)>=3Order by qty desc
however as any of you know, I'm only allowed the following header in the alert manager
SELECT Interfaces.FullName, Interfaces.InterfaceID FROM Interfaces
thoughts?
My SWQL is not up to this level of skill but maybe @sum_giais or @Seashore can help with that.
Sure, can this be what you are after? Same method as above, inner join the actual trigger query. Written in SQL, not SWQL.
SELECT Interfaces.FullName, Interfaces.InterfaceID FROM InterfacesINNER JOIN(SELECT count (E.EventID) AS qty ,I.InterfaceIDFROM Interfaces AS IINNER JOIN [events] AS E ON i.InterfaceID = e.netobjectidWHERE E.eventtime > dateadd(day,-1,GETDATE()) AND E.eventtype ='10'GROUP BY I.interfaceidHAVING count (E.eventid)>=3) AS Eventqty ON Interfaces.Interfaceid=Eventqty.InterfaceID
Everything except the first line is what you put in the code box.
When I run the query, my result doesn't show the qty (number of flapping for the giving interface).
Could be because you don't have any interfaces matching the filters. Try remove the line "HAVING count...." and see if you get any results back
no luck...still doesnt show the column for qty. But I did see results (juts not displaying my nodes in the pic below). I also tried to change the day to week to confirm I see results. Got the same output. Fullname | InterfaceID but no qty column.
Are you looking to include this count in the alert data .. either in the message data of the alert or in the email / comms sent?
Great - this is just the question I was coming to ask! Looks as though I'll be able to make use of some of these answers despite being an SQL/SWQL ignoramus.
