Greetings, I have a Fortinet computer that Orion recognizes as wireless controllers and it is not. what could it be?
This may be happening because Orion has assigned the "Wireless Autonomous AP" view to the Fortinet device type. If Orion is already seeing it as the correct machine type (via SNMP), then check to see what view is assigned on the "Views by Devie Type" page.
Go to All Settings-->Views by Device Type. Find the Fortinet device in the list and change the view to "default" if necessary.
Hope this is it.
Thank you very much Borgan that was it.
Glad I could help. Please mark my answer a Correct. Thanks.
ok there I mark the answer, but could you tell me where I mark the answer as correct?
Hmmm. Now that you mention it, I do not see the option to do that. There used to be a button to click under the answer. That;s OK.
