I'd like to shutdown polling on my main Orion sever and make it strictly and app server. Can I promote an existing additional polling engine to be the primary?
If I got you right... you only have to select all your nodes monitored by your Main Polling Engine, and change them to your APE.
You can do that on the Manage Nodes page.
Sorry. I want to eliminate the core poller and promote an additional poller to the primary status. I do not want the core poller to be an option when adding nodes. I intend the core server to be strictly an application server. No polling on the core. I do not want the core to be the primary poller.
Hello there!
The first server you install is always your primary server, unless you rebuild it. The primary server has things installed on it, such as the reporting and alerting engines, which APEs do not, and cannot have.Unfortunately you cannot promote an APE to a Primary. You can, however, rebuild the primary server, migrate all nodes from the APE to it, and then decommission the APE, leaving you with just the new, Primary, server (if you need to move an on-prem Primary to the cloud, for example).I'm curious, if you can share, what is the reason for wanting to do this? There might be another way around your problem which we can assist with
I want to reduce the resource usage on our core server by eliminating polling from the server.
Why don't you simply remove the nodes from your main poller and assign them to other polling engines? In your Manage Nodes screen under More Actions the action Change Polling Engine is available. Simply select the nodes and move them to another engine. We don't leave any of our nodes long term on our primary polling engine, we move them to the additional pollers. This takes some of the processing off of the main poller as well as providing a 'parking lot' for us so when a new node is added by 'in the field' users or during a discovery it lands on the main poller first. Then we verify it was added correctly, before moving the node to another poller.
If you want a new primary polling engine just stage up a new server, run the installer, and connect to the database. It is a simple process.
