When a field stops updating and SolarWinds data become stale is there a possibility to get an alert when that occurs and is there a future fix in the works from preventing this from occurring? Or where can I put this in a future feature?
Fields shouldn't stop updating, so I would focus here. Have you opened a support case on this issue and behavior?
yes
What fields are you referring to specifically? Without knowing more its hard to recommend a path towards resolution.
What steps have been taken if any thus far by yourself / support?
You could suggest if this may be of use and/or be an issue... but I find that clearing the information service subscriptions along with cleaning out windows temp files and a clean service restart (which I outlined in grave detail in the linked post below) to resolve numerous polling problems on the engines.
https://support.solarwinds.com/SuccessCenter/s/article/Clear-Information-Service-Subscriptions?language=en_US
https://thwack.solarwinds.com/product-forums/the-orion-platform/f/forum/93496/shutdown-restart-order/296293#296293
That said... I would really want to know more before doing that myself
We have a large system and lots of data being updated. For example there are no specific field areas. It could be random but when it occurs I would like to put notifications in place to test for it next time. Yes the majority of the time all fields are updating but then there will be a occurrence of stale data. I put last DB sync in most of the resources created that helps because the time tag is old that is an indication. That's my best explaination. Thanks
I will used the recommendations provided as well. Thanks
