I created a new group called SQL Servers, and added in there, all my SQL servers. I am having problem, the new SQL group doesnt appear in the manage groups, or on my manage nodes.
please advise me urgently. thank you.
Hmmm, not clear on why you are seeing this behavior. I would recommend a support ticket so they can look at your environment and advise.
My colleauge also using admin login can see my new DG, but when I login cant see it.
thanks for your response.
