I put together a dashboard and when I click on the node I get the following error:
{"errorCode": "404","location": "/apps/platform/xxxxx","errorType": "","message": "required path does not exist"}
Then you aren't including the Details URL in the dataset you are returning.
What's the definition of your link? Looks like it's set to View.apsx?NetObject=N:## which won't work from modern dashboards. You should use the DetailsUrl item when possible.
Thank you very much for your prompt response. I am just doing it by DetailsUrl, but when I want to enter a node I get the error that I mentioned before
The Details URL needs to contain an actual URL, so it also needs to be a part of your dataset that you are returning.
Of course I understand, but in Details URL it doesn't let me paste a URL, I get a single potion that is name
excellent, that was what I needed. thanks a lot
