Does this account have admin rights in Orion?
All information is correct, please help.
yes bro
this is admin credintial IT
The systems engineer is the one who has the authority to download the ageint into the servers
Does that account actually exist in Orion? Can you log into your Orion console using it?
Ask your system admin to validate this in SolarWinds
1. Orion IP Address correct - ? 10.1.240.56, Yes then step 2
2. Is port open between the server (where you are installing this agent) and SolarWinds - ? Yes, then point 3
3. Login into SolarWinds, go to Settings -> All Settings -> Manage Accounts (which is under User Accounts), check if you can see 'sshahed' account and as well ask him to verify if it has 'Admin Rights' - ? Yes, then step 4
4. Try to login into SolarWinds URL https://10.1.240.56/Orion using 'sshahed' account and password.
did you checked whether you are able to access console using the same username & password
