Site to site VPN Tunnels showing incorrect information, after enabling CLI polling on devices.
yeah, if your not going to provide more information, i wouldn't expect the community to help you.
Actually, i have enable the CLI polling on Cisco ASA and firepower but still getting the wrong information. On device it's showing multiple tunnels are showing down but when I check the tunnel with IP address, it's not their on the firewall configuration.
Congratulations is not there but on Solarwinds it's still showing down, ideally it's should be removed from Solarwinds console also if configuration is not theirs on device.
This the issue which I m facing.
