Hi - is there a way nodes can be identified via Country via swql on a modern dashboard
so if a node contains the letter 3 it is UK based etc as per below
3 - UK
5 - Roi
7 - NL
9 - BE
thanks in advance
I'd filter results with the where added to first, and count them after, something like this.
Select Count(t0.Caption) AS KPI_Numbe, t0.LocationFrom (SELECT N.Caption, Case when N.Caption like '%3%' Then 'UK' when N.Caption like '%5%' Then 'Roi' when N.Caption like '%7%' Then 'NL' when N.Caption like '%9%' Then 'BE'Else 'unknown'End as [Location]-- ,-- Case-- when SubString(N.Caption, 2, 1) like '3' Then 'UK'-- when SubString(N.Caption, 2, 1) like '5' Then 'Roi'-- when SubString(N.Caption, 2, 1) like '7' Then 'NL'-- when SubString(N.Caption, 2, 1) like '9' Then 'BE'-- Else 'unknown'-- End as [Location2]FROM Orion.Nodes N WHERE Status=2 AND (nodes.customproperties.AssetTag='Store Router')) as t0Group by t0.Location
I commented out the column for location2 with -- since I didn't know what made more sense, I just picked one.
Does this help?
Excellent then yes it's much easier. Basically '9%' becomes any word beginning with 9.
So '3%' for UK, '5%' for ROI etc
SELECTCount(N.NodeID) as [NL]FROM Orion.Nodes NWHERE N.Caption like '9%'AND N.Status = '2'AND N.CustomProperties.AssetTag like 'Store Router'
Perfect - works great thank you
SELECTCount(N.NodeID) AS [UK]FROM Orion.Nodes NWHERE N.Status = '2'AND N.CustomProperties.AssetTag LIKE 'Store Router'AND (N.Caption LIKE '3%' OR N.Caption LIKE '4%')
As your doing an OR as well as an AND in your WHERE statement you just need to break it up. The (brackets) means it first looks for the 3% OR 4% in the Caption as well as Status 2 AND CP Store Router.
Sure, below I have a query, the first column is the node caption, and I try to find the location using a case statement in 2 ways. Location1 looks for the numeral anywhere in the name, Location2 looks for it as the second character with the substring function.
SELECT N.Caption, Case when N.Caption like '%3%' Then 'UK' when N.Caption like '%5%' Then 'Roi' when N.Caption like '%7%' Then 'NL' when N.Caption like '%9%' Then 'BE'Else 'unknown'End as [Location1],Case when SubString(N.Caption, 2, 1) like '3' Then 'UK' when SubString(N.Caption, 2, 1) like '5' Then 'Roi' when SubString(N.Caption, 2, 1) like '7' Then 'NL' when SubString(N.Caption, 2, 1) like '9' Then 'BE'Else 'unknown'End as [Location2]FROM Orion.Nodes N
Sorry should have been more clearer also needs it to contain the following -
SELECT COUNT(1) AS KPI_Numbe from Orion.Nodes
WHERE Status=2
i have tried it but it does not like the swql im not sure why not
this is the error i am getting -
I didn't have that custom property so I tested with it comment out, I didn't edit your line to use my alias for nodes. We may also want to replace '=' with 'like' since its a string comparison.
Find: AND (nodes.customproperties.AssetTag='Store Router')
Replace with: AND (N.customproperties.AssetTag like 'Store Router')
I hope that fixes it.
Yes that works a treat thank you, is there a way that this can be output to the kpi widget for each country ?
Each box in the kpi widget is its own SWQL statement, so just filter the where with the same logic as the case statement, and use the label. Something like:
SELECT Count(N.nodeid) as [UK]FROM Orion.Nodes N WHERE N.Caption like '%3%' and Status=2 AND (n.customproperties.AssetTag like 'Store Router')
if i wanted to include 3 countries in one widget how would the swql look ?
One widget, just add values with its own SWQL Configured like this:
I use SWQL in modern dashboard, But I save my city data in Table Orion.NodesCustomProperties
SELECT TOP 10 ncpg_province, count(ncpg_province) as num_province FROM Orion.NodesCustomProperties GROUP BY ncpg_provinceORDER BY num_province DESC
Yes thank you
