Hi All,
Dependencies have stopped working from few months , it was working fine earlier.
Any suggestions please
was this ever resolved?
hi vandu,
Do you know if this was after an upgrade or did something change in your environment for the dependencies to stop as you described?
Hi Mjacomb,
we have performed multiple upgrades not sure what has caused this. It stopped working from few months
@vandu Have you opened a support ticket for this issue?
Yes support case has been raised
What sort of dependencies do you have in your environment ? Is it auto dependency or manually created ?
I agree, support ticket is the way to go, if you don't get an acceptable response via support, ping me.
No It is not resolved.
We have manual dependencies created where we have WAN setup and LAN setup accordingly dependency created.
Raised a support case but no luck on it.
Please provide your suggestions if any.
