Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Text to speech pronounciation
RobMilman
We have "trianed" Orion to pronounce nodenames properly for alerts. When we test the alerts the nodenames are pronounced properly. But when a real alert is triggered, it does not pronounce the nodename correctly.
Any thoughts on why this does not work?
Rob Milman
Find more posts tagged with
Accepted answers
All comments
DonYonce
Good Question !
Depending of the speech engine you used (yes, Orion can use many different speech engines) you will need to copy the lexical dictionary from your user id to the "System" user ID. The reason for this is that when you configured the pronounciations, you were logged in with your user ID. When you tested the Alerts, you were logged in as your user ID, But... when Orion actually triggers the Alert it is running as the "System" user ID.
So... here's how to copy your pronounciation dictionary to the System user ID for the Microsoft Speech Engine (The Voice named "Sam").
Look in the following directory :
C:\Program Files\Common Files\Microsoft Shared\SpeechEngines\TTS\Lex
There will be a file with your user ID as the name and the extension of ".lex".
Copy this file to the name "System.lex"
By the way... this is a text file that you can edit with notepad.
RobMilman
Thanks Don,
That is what I thought was happening, I just wasn't sure where to begin looking.
Best Regards,
Rob Milman
PS: You don't know where I can find a Cylon voice do you? Just for fun of course!
Rob Milman
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
