Hello,
is there a way for me to manually enter a ticket here. IE let's say I create a ticket and want to show up here instead of when it's auto-generated by the integration?
No, that is not how this function works. This widget will only display incidents that have been generated by the Orion alerting engine.
If you want to create something more than this, you may be able to do so via the Custom HTML widget, by creating some Javascript code that pulls data from the SNOW API for display.
after some help / advice with regards to creating a widget for Snow Incidents on a Modern Dashboard - much appreciated
The incident data from the SNOW integration is stored in the SWQL entity Orion.ESI.AlertIncident, so have a look at this entity to see the data you can access, but the following query may be a starting point for you:
SELECT a.AlertConfigurations.Name, a.EntityCaption, a.AlertActive.TriggeredDateTime, a.AlertActive.TriggeredMessage, a.AlertIncident.IncidentIDFROM Orion.AlertObjects aWHERE a.AlertIncident.IncidentID IS NOT NULL
Have used the above but it only shows triggered alerts - i need it to include the service now incident number etc
Did you have a look at the Orion.ESI.AlertIncident SWQL entity to see what data exists?
If you have SWQL Studio installed use that. If not and if you are not likely to do much custom querying, then navigate to the following URL
https://<servername>/Orion/Admin/swis.aspx
Delete the default query and in the Generate Query drop down, select the Orion.ESI.AlertIncident entry and click Generate. This will show all of the columns and the data within it. Identify the column that has the SNOW Incident ID's in it. You can then update the query above to use that or for the count of Incidents Orion has integrated to create:
SELECT COUNT(ID)FROM Orion.ESI.AlertIncidentWHERE <ColumnNamewithSNOWID> IS NOT NULL
I do not have access to instance with such data currently to confirm I am afraid, but this should get you where you need to go.
right - i have tried the above which works - but i need it to go into a kpi widget to give the total number of incidents rather than incident number, assignedto etc etc
Replace in the following SWQL query the name of the column in the Orion.ESI.AlertIncident entity, which is storing the IncidentID. I do not have output in front of me, but from memory it was the IncidentID field. This query will output the number of alerts which have an Incident ID from SNOW it has collected as part of the alert integration.
SELECT COUNT(ID) AS IncidentCountFROM Orion.ESI.AlertIncidentWHERE <ColumnNamewithSNOWID> IS NOT NULL
Just trySELECT COUNT(ID) AS IncidentCountFROM Orion.ESI.AlertIncidentWHERE IncidentID IS NOT NULL
Is this for all tickets raised or just open tickets ?
this is just for tickets that have been pushed to create Incidents in SNOW. You can add other clauses to the WHERE to focus on things such as stage if you like
Glad it is working for you!
Would appreciate your help on swql for just open tickets - not to sure on the correct structure
It is worthwhile you looking at the basics of SQL/SWQL, as if you have this requirement now you are going to have more in future. The following is the standard place to start learning - https://www.w3schools.com/sql/sql_where.asp
In the following adjustment to the previous statement, you can see I have added an AND, which means both the IncidentID field is not empty and the state field must equal a value, where you replace <value> with the value that equates to the ticket still being open.
SELECT COUNT(ID) AS IncidentCountFROM Orion.ESI.AlertIncidentWHERE IncidentID IS NOT NULL AND State = ''
Have tried the above and tried open and assigned as a value but 0 is being displayed
