Good Afternoon thwack community! I've been trying to mess with the SQL query or the graphical query builder but can't seem to get the network wide availability % (as a KPI widget) and same with vpn connected users. Anyone had any luck? Thanks!
@famore @nz1jvb
Guys, i set this up for my environment and works fine for me, we use Cisco Anyconnect as the VPN client.
VPN Widget
To achieve the above i used the SWQL below where the XXX is the Solarwinds NodeID of your ASA devices, we only have 2, but if you have more then that line will need expanded to include all of your ASA Devices
SELECTcount ([data].[RemoteAccessSessions].[UserName]) AS [Number]FROM orion.asa.node AS datawhere [data].[RemoteAccessSessions].[EncryptionAlgorithm] = 1and ([data].[RemoteAccessSessions].[NodeId] = XXX or [data].[RemoteAccessSessions].[NodeId] = XXX)and [data].[RemoteAccessSessions].[DisconnectedTime] is null
Network Availability Widget
To achieve the above widget i run the following SWQL query - bearing in mind that in my instance i'm looking at the last 30 rolling days and we have less that 2000 Nodes, these values below (in bold) would require adjusting for your environment.
select avg(orion_responseTime_availability_avg) as Net_Availfrom (SELECT TOP 2000 aggSub._avg AS Orion_ResponseTime_Availability_avgFROM Orion.Nodes nLEFT JOIN ( select i.nodeid, avg(i.availability) as _Avg from orion.ResponseTime iWHERE (i.DateTime > ADDDATE('day', -30, GETUTCDATE()))group by i.NodeID ) aggsub ON aggsub.nodeid=n.NodeID )
Trying to find the same thing, would love to see some examples
thank you!!! that worked!
I compared it to my ASA also and connected users is accurate.
@dunky2k
really appricate that reply!
Quick question, for the network availability, i was playing with the SWQL commands but is there a way to change it to "current month average"? So it updates on a daily basis's for the month and resets the average every month.
Thank you!!!!!!!
Thanks a ton, that worked perfectly
@famore
if you change the 'WHERE' statement to read as below instead, this should give you the stats for the current month only and reset on the start of each month.
WHERE (MONTH(i.DateTime) <= Month((getdate())) and MONTH(i.DateTime) >= Month((getdate())))
sorry - you used an ASA query on your Palo and you got back connected vpn users? The only thing you modified was the node ID?
Thanks for sharing this, the only question I have is how do I get the average to not exceed 3 decimal places? I got this set up and ended up getting 14 decimal places. I like it, but its a bit long. Thanks
I forgot where in thwack I found this for a different example. You can use the below round function to limit the decimal places.
ROUND(AVG(orion_responseTime_availability_avg),3) AS Net_Avail
Thank You!! This worked great!
Hi - where about in the query does the above go ? thanks
i sorted it
