What in tarnation is error code 1232?
Nodes went down siting error code 1232, however, they were accessible from the polling engine via ping, there is no documentation on this error code.
Is anyone familiar with this?
Not come across that code before but can I ask what the end hardware is that caused this? It might have some relevance.
Failing that I'd log an incident with SolarWinds.
At this time, its Calix device, a handful of them at the same time
Ahh, I can't help there as we don't have nay here. And a Google search doesn't reveal anything of relevance that I can see.I found this for error 1231: https://support.solarwinds.com/SuccessCenter/s/article/Node-Error-Code-1231-PING-Transmit-Failed?language=en_US but nothing on 1232.Time to raise a ticket if it's still an issue.
thanks i found the same, guess ill open a ticket
When you get a response it would be good to post your resolution here for others to find down the road.
