All, I am looking for some SWQL/SQL code that can pull out the following information from the database.
Columns Include:
You can use this query as an SWQL report or as a Query Widget. It is excellent as a widget as it includes hyperlinks. Credit to the original creator for adding all the comments!
select n.caption as [Device]-- shows the current status icon, '/Orion/images/StatusIcons/Small-' + n.StatusIcon AS [_IconFor_Device]-- makes a clickable link to the node details, n.DetailsUrl as [_linkfor_Device]--Show Mute Node Down Custom Property, n.customProperties.IgnoreNodeDown-- shows the timestamp of the down event, if there is no timestamp then is says the event was greater than the number of days in your event retention settings, isnull(tostring(t2.[Down Event]),concat('Greater than ',(SELECT CurrentValue FROM Orion.Settings where settingid='SWNetPerfMon-Settings-Retain Events'),' days ago')) as [Down Event]-- shows the timestamp of the up event, unless the object is still down, isnull(tostring(t2.[Up Event]),'Still Down') as [Up Event]-- figures out the minutes between the down and up events, if the object is still down it counts from the down event to now, displays 99999 if we cannot accurately determine the original downtime, and , isnull(MINUTEDIFF(t2.[Down Event], isnull(t2.[Up Event],GETDATE())),99999) as Minutes,n.Vendorfrom orion.nodes nleft join (SELECT -- Device nodeid used for our join StartTime.Nodes.NodeID -- Down Event time stamp in local time zone ,ToLocal(StartTime.EventTime) AS [Down Event] -- Up Event time stamp in local time zone ,(SELECT TOP 1 ToLocal(EventTime) AS [EventTime] FROM Orion.Events AS [EndTime] -- picks the first up event that is newer than the down event for this node WHERE EndTime.EventTime >= StartTime.EventTime -- EventType 5 is a node up AND EndTime.EventType = 5 AND EndTime.NetObjectID = StartTime.NetObjectID AND EventTime IS NOT NULL ORDER BY EndTime.EventTime ) AS [Up Event] -- This is the table we are querying FROM Orion.Events StartTime -- EventType 1 is a node downWHERE StartTime.EventType = 1 ) t2 on n.NodeID = t2.nodeid-- this is how I catch nodes that are down but have aged out of the events tablewhere (n.status = 2 or t2.nodeid is not null)-- If you want to filter the results to only show outages of a minimum duration uncomment the below line--and MINUTEDIFF(isnull(t2.[Down Event],(GETUTCDATE()-30)), isnull(t2.[Up Event],GETUTCDATE())) > 60-- if you want to use this query in a search box of the Custom Query resource uncomment the below line--and n.Caption like '%${SEARCH_STRING}%'--Filter on Vendor---and n.Vendor like '%Windows%'order by t2.[down event] desc
OK... the start of this query was online somewhere...i have made it my own... OF COURSE>>>>> IF YOU USE THIS IN A LIVE ENVIRONMENT, it is not supported by SolarWinds! USE AT YOUR OWN RISK...
Now, after saying that... you will most definately have to modify this for your environment..as i am using some pulling down some custom properties that are only on our environment...
SELECT * FROM ( SELECT --Nodes.StatusLED, Nodes.Caption, Nodes.NodeID, Nodes.Is_Production, StartTime.Message, StartTime.EventTime AS DownEventTime, ( SELECT TOP 1 EventTime FROM Events AS EndTimeTable where EndTimeTable.EventTime >= StartTime.EventTime AND EndTimeTable.EventType = 5 AND EndTimeTable.NetObjectType = 'N' AND EndTimeTable.NetworkNode = StartTime.NetworkNode AND EventTime IS NOT NULL ORDER BY EndTimeTable.EventTime ) AS UpEventTime,DATEDIFF(Mi, StartTime.EventTime,( SELECT TOP 1 EventTime FROM Events AS Endtime where EndTime.EventTime > StartTime.EventTime AND EndTime.EventType = 5 AND EndTime.NetObjectType = 'N' AND EndTime.NetworkNode = StartTime.NetworkNode ORDER BY EndTime.EventTime) ) AS OutageDurationInMinutes FROM Events StartTime INNER JOIN Nodes ON StartTime.NetworkNode = Nodes.NodeID WHERE (StartTime.EventType = 1) AND Nodes.Is_Production = '1' AND Nodes.Model = 'Server') AS UpTimeTablewhere outageDurationInMinutes IS NOT NULLORDER BY Caption ASC, DownEventTime ASC
Yes, I am sure I will need to modify the script. I am getting "There was an error processing the request" at the moment.
Just be forewarned that the "Events" table (one of the sources of this query) typically does not have the same historical settings as the Response Time details tables.
I am trying to use above sql query but its giving me an error as Invalid column name 'Nodes'. at StartTime.Nodes.NodeID
Please suggest
If you would, please give us more details on what you are trying to do? Maybe you can post your exact code??
Also, the above query is not for SQL.. it is for SWQL
Thanks John,
I am using the above mentioned SWQL script to generate report. But its giving me an error Invalid column name 'Nodes'. at StartTime.Nodes.NodeID line in the script.
Am I missing anything here?
there are actually two different scripts above... which are you using? The one that I posted? or the one that sten posted? can you post the exact script you are trying to use?
The one which sten has posted.
Are you trying to run this query in SWQL Studio?
When I try to run his Query in SWQL Studio I get an error
for your error... try changing 'Nodes.' to 'Node.'
It didnt work, same error.
for the error posted above you must either comment or remove line 7 from the query. It is referencing a custom property that you likely do not have,
Hi, I am getting error on line number 18 where its saying invalid column name node, custom property I have already removed
Trying to modify it to group by Device and Order by Down Event in descending order but getting an error. What is the syntax for that?
Show me what you have tried, and the error you receive, please
Also, are you using SQL? or SWQL Query?
I'm using SWQL for Stevenstadel's query and getting the "there was an error processing the request" message.
I tried placing "group by n.Caption" immediately before the "order by" statement at the end.
