I am trying to re-add the Vcenter to Solarwinds VMAN HF3. The Vcenter is added successfully but it displays Unknown Machine type. Also the VM's are not populated under the Vcenter.
Does it pass the credential test? Was it working ok before you deleted it and then re-added it?
Yes it passes the credential test. It was working before deletion. After re-addition the Vcenter displays Machine type as Unknown. The polling method is set to ICMP and not able to modify to vman orion, if that adds to helpful inputs.
@mahesh.sonavane, can you paste screenshots of the wizard within Orion you used to add it? there is a different way to add virtual infrastructure
In Virtualization Polling Settings, is the polling status green?
No I do not see any vCenter server added to the list
If you go to Manage Nodes, select the Node and click on Edit Properties, is this box ticked and details filled out and tested?
I have this exact same problem. vCenter was in Solarwinds monitoring and worked. Removed vCenter, then added it back. Credentials passed. Now, the status and machine type now show as 'unknown', so almost like SW doesn't know it's a vCenter. Also, the ESXi servers do not show up.
