Is there a limitation in my Solarwinds environment with 6k servers to deploy the agent on each one ?
Is there a limit of servers that I can deploy in my environment ?
I cannot find it documented .
A single polling engine can support up to 1,000 agents with default polling enabled (CPU/Memory utilization, response time). You will require additional polling engines to achieve this scale.
Thank You -
Where can I find this documented pleasssse!
Scalability Engine Guidelines for SolarWinds products Under "Orion Agents"
