Language suggestion in the new web interface. Option disabled and not supported in 15.3.
I'm forcing for example the Spanish language and there are so few strings in spanish.
We have identified this console issue for server settingGlobal > Limits & Settings (Password)Allows users to recover passwords: NoCurrent workaround to make login language option visible is to set above to: YesAlready fixed in code and to be part of next service release.
