hello every body,
please in the company where I work i am looking for report on all SAM nodes, that is to say, I want a list of the equipment which consumes the SAM license in detail
best regards
Hi
Thought that would be an easy one to answer. Thought first that all nodes polled with WMI took a license but that it not the whole truth. Then checked if polled with wmi + agent would be close to truth. Close but not exactly.
Also, it depends on what other modules you have:
The term "managed node" can be interpreted differently, depending on if you're using other Orion Platform modules with SAM:
So first, witch one of above scenarios do you have? SAM only or several modules? Expect that you have SAM Node based licenses.
hi, thank you.
i have NMP, NCM, SAM, NTA
i have the list of all NCM nodes, but not yet the all SAM nodes
This query seem to add up. How does it look on your side? Does the number of nodes returned match what orion license page say? Use this as base for your report.
SELECT N.Caption ,N.IP_Address ,N.MachineTypeFROM Orion.Nodes AS NWHERE N.NodeID IN (Select DISTINCT Nodeid FROM Orion.APM.Application) OR N.NodeID IN (SELECT DISTINCT RelatedEntityId FROM Orion.APIPoller.ApiPoller WHERE RelatedEntityType='Orion.Nodes')
yes, the licence SAM say to us that we had used more than 700, and this querry give us only 23 nodes
we try to understand why is more than 700 ,
Are you sure you are using SAM with Node based licensing and not Component based licensing?
where can i found this please? to be sur
Go to Settings/All Settings and then "license manager" (URL should be like YourOrionServer/.../license-manager)
Find your SAM License. If it says something like "Server & Application Monitor SAM1500" you have node based licenseIf it says something like "Server & Application Monitor - ALX" you have component based license
What does it say on your system?
Another way also:
Go to Settings/All Settings and then "license details" (URL should be like YourOrionServer/Orion/Admin/Details/ModulesDetailsHost.aspx)
Find SAM:
"Number of nodes allowed due to license" = Node based license"Allowed Number of Component Monitors" = Component based license
On the Orion demo online you can export this report into your environment
@neomatrix1217 good find. I'm definitely grabbing that report. Thanks for sharing the find.
thank you, but not about component licensing
Not sure if this will help but you can get List of SAM components and their Ancestor/Parent by running this querry:
SELECT Name, AncestorDisplayNames, DisabledFROM Orion.APM.ComponentWHERE Disabled = 'False'
Evening fun, SQL queries..... :-)
Composed a query that counts the component cost and take into account the specific cost for the appinsight templates. For some reason I don't get exactly the same number as the license page. But it's pretty close. Might be ok.
Import below as a report and see if it looks ok.
[View:/cfs-file/__key/communityserver-discussions-components-files/19/SAM_2B00_Component_2B00_based_2B00_licenses.xml:640:480]
If you only want the SQL query it looks like this:
SELECT Caption, SUM(Cost) AS Licenses FROM(SELECT N.Caption ,Count(C.ID) AS CostFROM Nodesdata as NINNER JOIN APM_Application AS A ON N.NodeID=A.NodeID AND A.Unmanaged=0INNER JOIN APM_Component AS C ON A.ID=C.ApplicationID AND ISNULL(C.IsDisabled,0)=0WHERE A.TemplateID NOT IN (273,308,430,587)GROUP BY N.CaptionUNION ALLSELECT N.Caption ,SUM(CASE WHEN A.TemplateID=273 THEN 50 -- AppInsight For SQL WHEN A.TemplateID=308 THEN 50 -- AppInsight For Exchange WHEN A.TemplateID=430 THEN 30 -- AppInsight For IIS WHEN A.TemplateID=587 THEN 50 -- AppInsight For AD END) AS CostFROM Nodesdata as NINNER JOIN APM_Application AS A ON N.NodeID=A.NodeID AND A.Unmanaged=0WHERE A.TemplateID IN (273,308,430,587)GROUP BY N.Caption) as ZGROUP BY Z.Caption
