Hi
you just can not compare a vendor EMS with a open NMS.
Its sure a good idea to get the vendor EMS if your shop is only on type gear..
But most network are a mix of vendor where NMS make much more sense ..
Is this copy and pasted from the vendors' websites? We have both of these platforms BTW.
