The Description variable of Orion.Routing.Neighbors is not populated for any of our hundreds of routing neighbors. When I try to update this variable I am not allowed to. How is this variable populated, and is there a way that I can write to it?
solarwinds.github.io/.../Orion.Routing.Neighbors.html
Are you pulling the routing information for your devices under "List Resources"?
Yep, all of the other information is populated, but none of the 200+ routing neighbors have any information in Description. When I try to run an update against it to add my own info, it is not allowed.
Correct. That particular entity is read-only and can only be updated by the Orion system itself. If it's not populating, and you aren't getting neighbor information in the web console either, you should open a support case. Something's not coming in correctly.
Is there a definition anywhere of what information should be populated in this description? Where would you find this in the GUI? I've only seen this referenced in the API. Under Network I see this, but there is no description field.
Bump, anyone have ideas? How can this field be used? Would be nice to be able to write to it via API instead of having a blank description field for every neighbor.
I shared this a little while ago. I guess I forgot to post back here.
Routing Neighbors for a Single Node - Custom Queries - The Orion Platform - THWACK (solarwinds.com)
Sorry about that.
Not seeing where that post relates to the Description field that can be found in the API, am I missing something?
Sorry - got my lines crossed here - I was working two similar forum posts here.
The description field is not populated and may not in any records in this table. Description is a field that appears to be mandated by the API architects for all entity types. If the API already has a better descriptive entry, then you should use that one.
Description
My guess (I'm not one of the architects) is that this way if a query is called like:
SELECT Uri, Description FROM <EntityName>
It'll at least not fail for whatever entity is provided.
Thanks, so its not used and not able to be used.
Are there any ways you can think of to be able to write descriptions per routing neighbor that can be used in alert emails? Currently the only way I've thought to do that is with create a separate SQL table, but then that must be updated through SQL and not the API. If there is a way to do this with custom properties or something associated with the actual routing neighbor, it would be much more preferable.
