Hi All,
Can we get a list of all alerts a node can trigger(for all nodes). Also list of all volume and interface alerts it can trigger.
Regards,
Devendra
There is a per object resource called "All Alerts This Object Can Trigger" which can be added to the interface and volume details views. An example of which can be seen here https://oriondemo.solarwinds.com/Orion/NetPerfMon/NodeDetails.aspx?NetObject=N:337
Does that provide the info you need?
Hi Tony,
@tony.johnson Thanks for quick revert. But i want list/report of all the alerts a node can trigger , for all nodes in my environment. I don't want to go to each node and check which alerts it can trigger, if i can get a list/report that would be very helpful.
That would provide a little more challenging and may not be easily achievable with SQL/SWQL. Let me see what I can find from a little lab work.
There is no easy way I can see to create a report for configured alerts that can be triggered by each node by using SWQL or SQL. I have a few thoughts around how to get this data and may be able to work through some ideas over the next few weeks.
Hi @tony.johnson can we get this report ?
I have yet to find a clean solution to getting this data for a report. Once available I will share here.
Do we have update on this? If this is not possible, I understand.
