Need to add multiple/Bulk Component in SolarWinds.
Is there any way to add multiple/Bulk Component in SolarWinds. Using API ?
Need to create script to add component in solarwinds.
There are many ways to perform bulk actions via the API such as bulk delete / unmanage etc. When you state the component, what does it mean to you? Is it an application component you want to add to an application template?
Yes , application component.
documentation.solarwinds.com/.../sam-work-with-component-monitors.htm
When you assign an application template to 1 or more nodes, it becomes an instance of an Application Monitor. Any changes you make to the template are propagated to the application monitors. It may be all that you need to do is add the component to the template. https://documentation.solarwinds.com/en/success_center/sam/content/sam-template-application-relationship-sw1255.htm
There isn't a way to do this with the API at present and what @tony.johnson recommended (adding it to an Application Template) is the accepted way to add components to multiple Applications at a time.
Is there any documentation on how to add a component to an application template via the API? Is it even possible?
