hi
i have created following hyperlink buttons on MAP to acees dashboard from single page , any way to make same so that i can be displayed on view page as this MAP display get continously auto refresh.
I apologize, I am still not sure what you are after when you say add these on a page view. However, let me attempt to give you some options and see fi that helps. If you are not interested in using a map and are only after a basic widget to expose these hyperlinks here are a couple of alternatives.
1) The User Links Widget - Add a name, and a URL... thats it. It can open in the same window, or a new window if you prefer.
2) If these are another managed/monitored entity such as a Group or Map, you can always use a custom table, and enable the "Details Link" behavior. So you get something like this where you can drill down from the name.
Hopefully this helps, if not please let me know what I am missing.
I apologize @makecrazy - It appears you have a map that essentially provides links to specific dashboards, I think I got that part. But what are you trying to do and can you clarify where you are running into the problem? I am just having difficulty interpreting what you need and hoping to help.
I want to make page view in this style not in MAP , as map get continues auto refresh.
Any way to add these hyperlink button on page view
i need to add buttons in page view that have hyperlink in it like i made in MAP
is this possible.
thanks for detail reply
Big visual buttons would really only be possible using Orion Map or perhaps a custom HTML widget. Basic Hyperlinks on a dashboard would be from the two widgets mentioned above.
ok
these are basically Modern dashboard links that are hyperlink on that buttons so that team can access these dashboard from single page.
