Hi
Run Into that ...is that a bug ?
Its not moving to any other state.
I try to stop & disable/enable the job.
work around
Where is this? I have same problem (Post Processing...) for nightly backups with NCM 2020.2.5,
but I cannot find "LegacyTransferJobCollectorProcessing" or "JobsParallelConfigProcessing" under NCM Settings.
This is under the Global Admin settings which is only accessible via URL (there is no link to it under Settings).
https://YOURSERVER/Orion/Admin/AdvancedConfiguration/Global.aspx
Hi Kgrahamjr, I am also facing the same NCM job issue. Did you resolved this issue or still persistence. we are also using the same Environment. Could you please provide the solutions. Regards,
Krish..
Thanks for your answer, but I wonder... just HTH Solarwinds expects us to know this stuff? /smh
Krish... what I did was delete my jobs, and re-create them. That resolved my issue. Weird, But we'd been slow to the punch getting our SW upgraded after the fiasco. We were running such an old version that we weren't infected! After the upgrade completed, our server team said that the guy helping suggested that we may need to delete old jobs if they had issues and re-create them. Worked for me. /shrug
Thank you Kgrahamjr... But we kill the job and run it again. Now it is job status showing success. We will wait for next scheduled.
