Good day
I have question about Statistics Threshold, if they are about seconds, minutes or another thing ( in this case I using on Clock Drift monitor)?
Statistic threshold is using the value you pass to the SAM component. If you pass seconds to orion in the clock drift monitor, statistic threshold use seconds.
Hi
Thanks for the quick answer but on the "component monitor", in this case the "Drift" I only have option to insert the "pooling" time.
What do you mean with "Value you pass to the SAm component"?
So the script in the "script body" outputs a numeric value. That is the statistics value. In this component it's seconds.
Another script could count rows in a database, then rows is the output and the statistics value.
(I should have written "...value the sam component pass to you....", or "the value you get out from the sam component")
Got it?
If I understand, the value 5 for warning and 10 for critical of the image are 5 and 10 seconds
Yes, correct.
