Hi
i looking to make a Dashboard that contain Hyperlink Button .
Like
" Down Nodes Button" when user click it will open Down Nodes Report in new TAB.
If you're using an orion Map you can add the link to a picture or shape under "Behaviour". Personally use that most of the time. Lots of ways of doing this sort of thing depending on specifics
You can add a hyperlink under add resource - group by Type - then under custom resources - custom HTML or User Links.
I would add a pic but not found how you can now !
