Are the Read, Write and Total disk latency statistics representative of Milliseconds?
Yes, the latency values are in milliseconds. For IOPS it is commands per second and throughput is Bytes per second.
What forum would that be?
I've moved this thread to the proper forum.
VMAN.table name is VIM_VirtualMachineDisksStatistics_CS_cur (on the SQL Server)
@TomYacura - which product are you talking about? I want to make sure this gets put in the correct forum to get your question answered.
