We had to uninstall and reinstall our patch manager console server (DB is on a separate server and stayed the same). But the cert that gets pushed out to the clients seems to have changed and most of the servers are getting an error in the event log stating "“The certificate received from the remote server was issued by an untrusted certificate authority. Because of this, none of the data contained in the certificate can be validated. The SSL connection request has failed. The attached data contains the server certificate.”
I exported the cert from the patch manager server and imported it and it seemed to fix the issue. How do I push this to my 900 clients that are being managed?
Thanks.
